sr20?
TheLogikal1
07-30-2002, 10:39 PM
what engines fit in what gen 240sx?
do the blacktops only fit in the 97-98 240?
does the redtop only fit i the 90-94 240?
someone give the info please
NISSANSPDR
07-31-2002, 01:32 AM
The S13 engine both the red and blacktop fit in the S13 "BEST" that's from 89-94 (a 205HP engine stock)
The S14 engine (only blacktop available) fits in the S14 "BEST" and that's from 95-98 (220HP stock)
There's a S15 engine that can fit in the S14 better than the S13 but it CAN fit in both...(250HP stock)
PS: B4 u ask...there's no difference in the red and blacktop...just the blacktop's are newer than the redtops
SR20DETpower
07-31-2002, 02:21 AM
clear that up, no difference between the S13 red and black top motors. However the S14 blacktop is different(newer, more powerful, different turbo)
From what I have heard from a guy in Cali that does SR swaps, he says the S14 motor installs easiest and cleanest into a S13 or S14. Better then the S13 would... But if you put in the S14 sr20det into the S13 chassis(89-94) you will need the S14 engine mounts instead of the S13 ones.
TheLogikal1
07-31-2002, 07:38 PM
thanks for clearin that up guys
mdimich
09-10-2002, 10:06 AM
i am looking at building an sr20det and was wonder how much psi could the stock internals withstand and what psi the sleeves were rated at i want to run about 22 psi through the motor but i am unsure if i need to build up the bottom end to do this if anyone can help me let me know you can e-mail me at [email protected] thanks mike
J SPEC SilEighty
09-10-2002, 04:10 PM
The SR has been seen to handle 300-400 hp on the stock internals. At 22psi of boost you will most likely need to upgrade the bottem end. Also to run 22psi your going to need a new turbo along with many other things such as methods of delivering fuel, most likley and upgraded ignition, and a reprogrammed ecu. You will need a new turbo because the stock T25 (I'm just assuming your going redtop) will only be good to about 15psi then it will be past it's efficiency range and will just be blowing hot air into the engine and you will not be making power anymore.
malakiP2001
09-13-2002, 05:41 PM
Hey if any one is looking to buy parts from a 1991 300zx I will be more then happy to sell nothing is wrong with engine or body just want to sell for parts I think its smarter that way no body damage either every thing is perfect need to sell looking for a sr20 turbo charged to fit my 1995 200sx you can e-mail me at [email protected] thanks
malakiP2001
09-13-2002, 05:51 PM
NISSANSPDR
09-13-2002, 07:00 PM
What kind of Z parts are you selling...?
I need a few things if you have them...is your TT or NA? 2 seater or 2by2?
Thx
Thx
