ANyone use SeaFoam?
m2736185
06-04-2006, 12:48 PM
Well I have been doing a lot of reading on this Miricle Drug they call seafoam then I head of this other product Mopar CCC..which seems the same as Seafoam "deep creep". Now as far as I understand there is the "Deep Creep" which like the Mopar CCC is in an aerosol can, and it is sprayed into the intake. Then there is the Sea Foam Motor Treatment which is sucked in through the brake booster line or you can put it right in the tank. Now my question is what is the main difference between the can version and the bottle version? Does the Bottle version do a better job? My other question is, i read that this treatment may add carbon not only to the spark plugs but the o2 sensors? I mean the spark plugs are no big deal but the o2 sensors are a bitch to replace and they are a lil expensive.
gotbitbyamoose
06-22-2006, 01:01 AM
yeah i use seafoam on a lot of the mechanical things i work on and it's great. all seafoam is is 100% petroleum. there is no difference between the spray can and bottle version. one may be alittle more corrosive then the other but thats for the different application they may be specified for. then for the carbon. well carbon is in everything and will eventually build up on the spark plugs and o2 sensors. then when you use the seafoam your just removing or loosen carbon and dirt deposits already there and may accelerate the natural gradual process, and you would do this anyway if you used the other stuff but they won't tell you cause its really nothing to worry about if you take care of your car. i don't know what car you have or how well it runs so you just do what feels best for you.
