Bad new !!
Killa
06-03-2006, 08:48 AM
I just talk to the owner, asking what kind of engine oil did he use. he say regular pennzoil :banghead: . I though turbo car only run synctec, I really want to use mobil 1 10w/30 and im scare to swith over cause the car now is
139000 mile, and it will leak. What should I do now guy ?.
SilvrEclipse
06-03-2006, 09:43 AM
With an engine that has that many miles on it, I wouldn't switch over to synthetic. It will probably leak like hell. Synthetic oil only protects the engine a little better, you don't have to use it. You might be able to get away with running a synthetic blend.
gthompson97
06-03-2006, 09:49 AM
You can use whatever oil you want in a turbo, it doesn't have to be synthetic. And I wouldn't switch over now, the synthetic will clean out all the buildup inside the motor and you may acquire a few leaks. Just run regular Mobil 10w30 in it
blk_srt
06-03-2006, 01:04 PM
I am using conventional oil because I have a leak and dont want to waste royal purple. Just run conventional untill rebuild time then you dont have to go through the headache of all your seals leaking
Killa
06-03-2006, 01:56 PM
He running pennzoil, you think I should stick with it ? or mobil 5000 ?. or max life ? ( Im currently run max life on my 215k mile eclipse, I love it ).
steviek
06-03-2006, 03:01 PM
You can still switch over to syntec if you want just gotta flush the transfer case. It might leak but meh if it leaks with syntec then it wasn't working properly anyways.
l_eclipse_l
06-03-2006, 03:31 PM
what does this have to do with engine oil?
gthompson97
06-03-2006, 06:12 PM
Do you know anything about engines and engine oil? The transfer case has NOTHING to do with engine oil and just because it leaks after switching to synthetic doesn't mean it wasn't working, it just means that the synthetic "cleaned" out all the buildup. Please don't post unless you know what you're talking about.
Killer, just stick with anything that's not synthetic. I like Mobil 5000 but you could run whatever you want.
Thor06
06-03-2006, 06:20 PM
I have a question... to switch to synthetic do you just switch or is there some elaborate way to do it?
gthompson97
06-03-2006, 06:22 PM
Well, I usually drain the old oil out, pull off the old filter, put synthetic in the new filter, install the filter, and then dump in 4-5 quarts of synthetic oil. :thumbsup:
Thor06
06-03-2006, 06:31 PM
:lol: Thanks jackass ;). I thought you had to do it gradually like go from dino oil to a 50/50 mix to a full synthetic. Good deal, I kinda wanted to go straight into synthetic.
blk_srt
Thats all a bunch of hype
gthompson97
06-03-2006, 06:43 PM
Haha I had to be a dick, you were just asking for it. :p
Talon69
06-03-2006, 07:12 PM
After i break in my engine i will be running full syn.
steviek
06-03-2006, 07:23 PM
I always flush my trasfer case when I get an oil change
second is the buildup good?? NO so then its not working properly.
blk_srt
06-03-2006, 07:32 PM
you can break in a motor with syntethic
Killa
06-03-2006, 07:49 PM
:evillol:
:evillol:
Killa
06-03-2006, 07:50 PM
Most of the people I knew, runing syntec blend first for about 2k mile, then after that running full synstec.
Killa
06-03-2006, 07:51 PM
it kinda wasted, but it true.
george536
06-03-2006, 09:14 PM
when i bought my car at 102K i switched over to mobil 1 synthetic, and no leaks at all, previous owner used nothing but regular pennz.
l_eclipse_l
06-03-2006, 09:48 PM
lol you seriously flush it that often? why?
Every engine running regular oil has a certain amount of buildup, even synthetics still have a little. Does that mean that every engine isn't working properly?
steviek
06-03-2006, 09:50 PM
Whenever I get it done at a shop
Thor06
06-03-2006, 10:21 PM
I think the T case is a 30k mile job. Sure doesnt hurt to do it more often though.
steviek
06-03-2006, 10:22 PM
agreed
gthompson97
06-03-2006, 10:43 PM
Word.
Word.
Killa
06-03-2006, 11:09 PM
Ok one last decision. best oil for 139k turbo engine. Please help me out
1- Mobil 5000 10w/30 ( I have this on my 97 rs, and it knock like mofo, but it cheap ).
2- Mobil clean high mileage 10w/30 ( never use this before )
3- Valvoline Max life 10w/30 ( My favore )
4- Pennzoil 10w/30 ( that what the owner been using on this TSI for year )
5- Castrol gtx 10w/30 ( last couple year, I only use 2 time on my rs )
6- Castrol High mile 10w/30 ( use one on my rs, before switch to mobil 1 syntec, and it leak :banghead: )
thanks.
thanks.
gthompson97
06-03-2006, 11:21 PM
My vote is for Mobil 5000. I've ran mobil 10w30 in every vehicle I own and have had not one single problem.
Killa
06-03-2006, 11:38 PM
mobil 10w/30 you mean mobil 5000 10w/30 ??
gthompson97
06-03-2006, 11:44 PM
Well yeah, but they just switched it like a year ago from Mobil 10w30 to Mobil 5000 10w30, 7500 10w30, or 10,000 10w30 (they have different mileage types now). They just used to make one regular Mobil 10w30, but now I just use Mobil 5000 10w30
steviek
06-03-2006, 11:51 PM
Thats just a cash grab if you ask me just trying to say like they've changed the formula to appeal to different drivers/
and as for the build up comment.. There is only so much you can remove but if you remove to a point where theres an oil leak... then you have a problem.
gthompson97
06-04-2006, 12:04 AM
I think its part that, but I think some of it actually works too, who knows. I run "5000 mile" oil but still change it every 2000 miles, it's just habit.
Obviously if there's an excess of build up then you have a problem, but a leak doesn't necessarily mean you have a problem either. Sometimes brand new seals will leak until they "set in and seal up" Changing over to synthetic could "unset" them and cause a leak, but you still have a new seal right? Not necessarily a problem, just an annoying leak.
blk_srt
06-04-2006, 12:05 AM
:1:
gthompson97
06-04-2006, 12:09 AM
I think you're part of that annoying leak crowd, aren't ya Scott? :)
blk_srt
06-04-2006, 12:32 AM
annoying is an understatement.
ez1286
06-04-2006, 02:10 AM
I thought you were supposed to break in engines with conventional because it creates more friction so the rings seat properly. It's also hella expensive for synthetic.
steviek
06-04-2006, 09:52 AM
My car has a rear main seal leak (arguably the worst kind) cause that means I gotta pull the transmission (Can't wait)> but I had to buy the seal from mitsubishi (25$) and also I can get at my starter which is shit.
