95 park ave no start
bejoly
06-01-2006, 07:50 AM
hi my 95 pa is stalling out on the first attempt to start after i have been riding it for say till it reaches normal operating temp. if the car sits for like 20-30 min. after driving it, it will start right up (rpms 1400) and then stalls out in 2-4 seconds. if i try to start again it's fine on the second try. i checked the fuel press. and doing an injector leak down test and thats fine. i tried to turn the key and prime the system a couple times before the initial start pausing 10 seconds between primes and it still would stall out on the first try but fine on the second try. when the car sits for 0-14 min it starts fine when hot and also when it is cold. thanx for any info in advance mark
HotZ28
06-01-2006, 08:44 AM
It sounds like your fuel system is normal if it has good pressure (38-45 psi) and holds pressure while running. You did not mention whether or not you changed the fuel filter, however, the starting problems you describe sound more like the classic symptoms of ignition primary heat related problems i.e. crank sensor or ignition module. First, check for spark from the coils while it is in a no-start mode. If you have a scanner that can read RPM while attempting to start, check that also. You can have the ignition module tested at Auto Zone for free, just pull it off and take it to them. Also, be sure to check the ICM connector for possible corrosion or loose connections.
