Broken Stud
dessler
05-29-2006, 10:55 PM
I have a 97 z71, when I was putting my front passenger wheel back on one of the studs broke off. Is this going to be an easy fix o should it go to the shop.
plathegame
05-29-2006, 11:06 PM
its easy if you have an air gun
dessler
05-29-2006, 11:37 PM
No air gun. Is it still possible?
98BlackTransAm
05-29-2006, 11:56 PM
i would just take it to a tire shop. last time i had my tires replaced they cross-threaded one bolt and broke off another (never going there again). be sure to buy a replacement bolt from somewhere like autozone tho,, they're less than $2 there while the dealership i beleive wanted about $25...:sly:
plathegame
05-30-2006, 10:32 PM
its possible if you can somehow keep the wheel from turning while you press the stud into place.
dessler
05-31-2006, 10:04 PM
Thanks, I got the stud and ill give it a try my self.
plathegame
06-02-2006, 11:51 PM
put a spacer between the lug nut and the hub on the stud when you press it in so you dont stretch the threads as easy
