Ticking sound
baby141
05-24-2006, 11:00 PM
I have a 2002 venture. It is making a ticking sound coming from the front driver's side. It appears to be outside of the vehicle since I can hear it more when I open the window. What can this be?
shooter_va
05-25-2006, 05:58 AM
Does it do it only at start up or all the time? Our van makes a ticking sound only at start up which is the valves for the ABS cycling.
renechua
05-25-2006, 09:00 AM
If only when running, check out your tires. There might be something stuck between the threads like a pebble or metal stuff. If during idling only, then it could be the valves during warmup as the former mentioned.
phipps
06-04-2006, 07:14 PM
Do you have an ABS light on? My van does that and I have been told that the ABS sensor on the driver's side is bad. Unfortunately the only way to replace the sensor is to replace the whole hub.
