Someone help me
ATXTSI
05-23-2006, 04:05 PM
I bought a 95 eagle talon tsi that was having engine trouble so i swaped the engine with a newer engine. im having problems with the starter. is there any change in a starter from 95 to 99?
gthompson97
05-23-2006, 11:31 PM
DON'T double post.
We need more info like what is it doing? Making noises, grinding, not engaging? All the starters should be the same.
ATXTSI
05-24-2006, 11:35 AM
The starter is not engaging. is switching the flywheel the only way.
-Josh-
05-24-2006, 11:58 AM
When you got this engine did it come with a flywheel or did you use it off the old one?
SLoe
05-24-2006, 12:08 PM
I hate to post without having dealt with the situation, but have you tried shimming it? Shim on just one side should move it closer to the flywheel. I am assuming our car's starters are just like everyother car's starters. If you get it too close to the FW it will whine, then either take one of the half shims out or put a full length shim in until you get it right. :2cents:
ATXTSI
05-24-2006, 12:27 PM
The new engine came with a new clutch and flywheel.
ATXTSI
05-24-2006, 12:28 PM
Well it wasn't a new fly wheel it just came with the engine.
-Josh-
05-24-2006, 12:34 PM
Did you inspect it before installing the engine?
defiancy
05-24-2006, 12:53 PM
1. Make sure you have the battery in right. If it's backwards it'll cause the starter to turn but not catch.
2. Best thing you can do after that is pull the starter out and try to reseat it. If that doesn't work try and get a new starter and replace the one on there.
You shouldn't have to shim or do anything to the starter. The tranny plate is there for spacing on the starter. If it's not catching it's probably that the motor inside the starter that pushes the actual part of the starter out is busted or not getting any juice. Or the flywheel is screwed up.
