It has begun...
Mike75
05-23-2006, 12:33 AM
Okay, I bought the engine,and it's at the shop along with some miscellaneous accessories I thought I should have replaced while everything's apart. Below is a list of the new stuff I've bought to put onto the new motor. The engine comes with the oil pump, oil pan, timing chain, timing cover, and cylinder heads (typical long block).
New Items:
Aluminum Radiator
Clutch Fan
Ignition Coil
Upper and Lower Radiator Hoses
O2 Sensors (both)
Water Pump
Power Steering Pump
Plugs/Wires
Thermostat
Alternator
Is there anything else you guys think I need to replace while the engine's out?
They're starting the work tomorrow, so please throw your ideas in here asap! Thanks!
97Bird
05-23-2006, 04:03 PM
Replace the front seal in the transmission.
JR Tigerstar
05-23-2006, 10:49 PM
New Motor Mounts
Mike75
05-24-2006, 09:50 PM
Yeah, the mounts are less than a year old, so the mechanic's going to check those out for me.
As for the transmission seal, I'll talk to him about that too.
Thanks guys! Keep 'em coming!
