Scan Tool
rrichard7
05-20-2006, 11:08 AM
I recently bought a 1994 Altima GLE. Are there scan tools for these vehicles? If so, any recommendations? I have an Actron 9135 for other OBDII cars.
Thanks,
Ray
bmkj02
05-22-2006, 01:01 PM
I dont know about a scan tool but I know the computer is behind the center console by the gas pedal. Remove the cover and there you will find it. On the computer is a knob to turn to run the self diagonstic. Turn it to the right all the way and wait a few secs and turn it back to the left to where the line is that says self diagonistic. To erase the code I believe you have to turn it all the way to the right then all the way to the left quickly. Hope this helps
rrichard7
05-23-2006, 07:06 AM
Thank you. I'll try it. I'm having Speedo/Odo/HUD issues. Car seems to run fine but display will go out and speedo to zero. It's an automatic. I've read that there is a VSS that can cause such symptoms. Car has 27K miles but sat dormant for nearly 6 years.
Thanks again
jserrano
05-23-2006, 02:07 PM
Your problem is quite likely a bad HUD instrument cluster.
rrichard7
05-23-2006, 07:50 PM
Did the computer. I got 5 slow and 5 fast which means everything is OK. Speedo and HUD have yet to fail again. Hope cluster behaves, not with my luck.
Thanks,
Ray
