Gas gauge dropping to 0 or below when car is in neutral
nikita7
05-12-2006, 01:20 PM
Lately my gas gauge starts showing 0 or below when I shift from N to either D or R. Than a once a car gets going it climbs back up to actual position. Anyone knows what might be causing this ?
BNaylor
05-13-2006, 11:32 AM
Does the fuel gauge work properly when in PARK, ignition to run. Engine not started?
nikita7
05-14-2006, 05:33 PM
Yes. This happens only when car is shifted in N and out. Gauge stays stable in all other positions.
BNaylor
05-15-2006, 08:59 AM
Sounds like something is affecting either the ground or signal to the fuel gauge. It does not sound like a fuel level sensor and float problem which provides the signal to the gauge but you never know. Have you ever done any work around the Instrument Panel (IP)?
