94 Altima Sitting for 6 years
rrichard7
05-02-2006, 05:54 AM
Hi, I'm new to the Nisan forum. I have an opportunity to buy a 94 Altima with low mileage from a relative. The best we can determine is that the car has sat in the garage and not been run since 2000. Any concerns with a car sitting this long and what should be done before trying to start it? I don't mind replaceing fluids, hoses, battery and the like but I don't want to put the engine and automatic trans. at risk starting it. Any advice would be great.
Thanks,
Ray
Thanks,
Ray
rrichard7
05-06-2006, 07:15 AM
No one wants to touch this one. So far, I have removed a nest fit for a king out of the air box (underside of filter element). The flat top / shroud (plugs, oil filler) must have been the dining room, loaded with remnants of acorns. I put a capful of 5W-30 down each spark plug hole. New battery today and see if the electrics come up and turn it over without spark plugs.
x1gary
05-06-2006, 09:03 PM
So your doing a full tune up before you .... Start the Car ? I know of a few things that might help ...
-G-
-G-
rrichard7
05-07-2006, 06:05 AM
Hi, Altima G
It's alive. It smokes and hopefully it will clear. Runs very strong around the neighborhood (tags expired 5.5 years ago). My main concern was NOT to destroy it after sitting so long. Now I have to get it through our state motor vehicle inspection. I changed the oil & filter and it is high on the stick. I know that I put 4 quarts in just like the owners manual said to do. Could this indicate 1/4" of sludge in the pan? I'm debating dropping some of the oil. Seals are a concern and I don't want to help them expire. I may be obssessing to much. It is running on 5.5 year old gas, my lawn mower won't run on 5.5 month old gas. I put Lucas injector cleaner and dry gas in the tank.
Any tips are more than welcome.
Thanks
Thanks
x1gary
05-07-2006, 08:11 PM
Sludge build up in the oil huh ... id run the car, till it gets hot then change the oil untill it comes out clear. 4 quarts is a lil too much ... it should take 3.6 ... 4 would make it over a bit. Try some carberator cleaner to clean out the throttle body ... (Where the intake is) ... You might want to change the Fuel filter. Mmm .. that all i could think of at the moment ... let me know what happens
-G-
-G-
rrichard7
05-08-2006, 09:04 PM
Thanks, the smoking has stopped. I like the fuel filter idea. My owner's manual says (just checked) 4qts with a filter. 3.6 makes sense, I drained 16 oz out and it is right at the top. Going to motor vhicle tomorrow.
Thanks for your input,
Ray
Ray
