air conditioning
irican
04-28-2006, 03:17 PM
hello to all i need a little help with my a/c!!
system is charged ,i have the gauge connected to the port behind the fans and it is in the blue which means it is charged, turn on the ac and the compressor does not kick in the relay and fuses are fine is there a pressure switch or control switch anywhere , i dont see anything except the plug that goes into the compressor any ideas???
GregA
04-28-2006, 07:11 PM
There is indeed a pressure switch in the A/C system. I have a link to where it is on this page (http://www.my-chevy-venture.com/other-information.html) (about half way through the table). This is for a 2001 - I don't know what year yours is.
Take Care,
Take Care,
irican
04-30-2006, 07:39 AM
can this be the reason why the comp. is not kicking in ,are there any other electrical connections for the ac to work i have a 98 do you have a part# for this part thanks! also i need to change the regulator on the driver side any good advise??
GregA
04-30-2006, 02:54 PM
The sensor sends a signal to the PCM (Powertrain Control Module) and then the PCM decides if it should turn on the AC compressor clutch (through a relay).
So if the sensor is bad, the clutch relay is bad, or any of the wiring between the components is bad, that could cause the problem.
Before replacing the sensor, I would do a little more testing to verify where the problem is.
As for parts (and part numbers), you can go to rockauto.com and find them there.
I am not sure what you mean by "regulator on the driver side" so I don't have any advise there.
Take Care,
Take Care,
irican
05-15-2006, 09:22 AM
yeah it is the window regulator got it from www.gm-car-parts.com (http://www.gm-car-parts.com) under 30$
still have not tackled the ac yet! thanks.
irican
06-02-2006, 05:13 AM
taking the van in today for the ac, hope not too expensive worse case its the compressor everything else is cool!!!! i'll keep you guys posted, thanks for your help greg
irican
06-03-2006, 11:07 PM
1)brand new compressor(not reman)
2)new accumulator drier
3)new pressure switch
4)orifice tube
5)radiator flush
6)vaccum and recharge both systems
total $975
way more than i expected but these guys were recomended by my parts guy
and he gave me a nice warranty, what could i do i have kids and summer is here (you can hang meat its so cold in there)!!!!!
4)orifice tube
5)radiator flush
total $975
