Stroker Kit Driving Me Crazy !!!!
SySt3mR00t
04-26-2006, 03:21 PM
HELP PLEASE !!!!!!! ... Ok so my motor is out apart bored, milled, honed, hot tanked ... all my parts are in for this 2.3 stroker im doing. AND I CAME TO A HALT! The wiseco pistons which are the Evo 8 Pistons with an .20 Overbore have 5 piston rings and 1 oil rail ring for a total of 6 rings per piston. The pistons came with no instructions and the stock pistons have far less rings. I do not know how to assemble these pistons. CAN SOMEONE PLEASE HELP ME!
Thor06
04-26-2006, 03:44 PM
:eek7:
What the hell are you asking? First off, I dont know if the Evo pistons work in our cars, SBR has different part numbers for them so I dont think they will. Who cares how many the stock piston has compared to the aftermarket? Do you not know how to put rings on? Honestly dude, if you get fucked up over putting piston rings on you shouldnt be rebuilding your engine.
Blackcrow64
04-26-2006, 04:17 PM
The number of rings should have no effect on them as long as the pistons bolt up to the rods... What was the compression for those pistons?
Thor06
04-26-2006, 08:51 PM
The Evo strokers on SBR are 9.0:1 while the DSM ones are 8.8:1. I'd be worried about the pistons hitting the head or coming out the bottom of the cylinder (or a piston ring).
scottsee
04-26-2006, 09:49 PM
Weisco has diffrent part #'s for the evo 46g3 & the DSM 4g63.
E-Klips
04-27-2006, 12:33 AM
You need to post pictures cause I have never seen a gasoline piston have more that 3 ring grooves.
The most rings there should be is 5. 1 ring goes on the top groove, 1 ring goes in the middle groove and 3 rings go in the bottom groove.
gthompson97
04-27-2006, 01:06 AM
Why are you running Evo pistons in your Eclipse? I hope you didn't buy an Evo stroker kit instead of an Eclipse kit. And also, shrink down your sig pic, it's enormous.
SySt3mR00t
04-27-2006, 06:12 AM
ok well ... im pretty sure i firgured it out last night. i called wiseco and the guy talked to me and said there was no diagram but he could explain it to me. well... my original problem was there was 3 piston grooves and 6 rings. No the 7-bolt Eclipse stroker kit i bought came with Wiseco Evo 8 pistons .20 over. Well when i called wiseco he explained to me that the only difference between the top and 2nd ring is that the top ring was seven thousandths smaller. Found those and set them at opposing gaps. next in the third gap i put in OIL RAIL-SPRING EXPAINDER-OIL RAIL. Now i had one ring left. The last ring was the OIL RAIL SUPPORT. This went UNDERNEATH the oilrail and spring expander sandwich. The support should be the VERY LAST RING i was told. So last night, me and my buddies got the wholt bottom end put togethor. But yes the pistons ARE evo 8 pistons from WISECO. It says it right on the box. They came in my 7bolt Eclipse 4g63 Stroker kit. When i called wiseco, the guy seemed to know his dsm's and said this should work.
gthompson97
04-27-2006, 06:32 AM
Hhmmm...weird but good that u figured it out. And I didn't mean to make your sig. pic that small, just shrink it a bit.
SySt3mR00t
OK ... i just got off the phone with wiseco and figured out the EVO 8 .. Eclipse dilema. The reason why my piston box says evo8 all through it on everything is because the pistons use the same piston rings and same layout. they both use the 8500xx kit. As stated before you guys where all right , my piston numbers do match with the 7bolt Eclipse kit and I have the 8:8:1 compression, not the 9:0:1.
defiancy
04-27-2006, 11:36 AM
Actually, without a diagram it would be hard to figure out the piston rings for the pistons. Each one has a specific place it goes on the piston. When I got my pistons my only saving grace was that the guys from the shop had gapped and labeled my rings in order.
Glad you got it figured out.
gthompson97
04-27-2006, 01:47 PM
:1: They each have a certain place and a certain way to go in (one side specifically goes up). I would probably fuck it up without some sort of listing or diagram.
SySt3mR00t
04-28-2006, 07:03 AM
ok this is probably my last post on this thread, but i thought i would post it to help people out in the future. Turns out that the EVO Stroker pistons and Eclipse Stroker Pistons from wiseco are IDENTICAL and even have the same part number. Here is the proof ..... http://www.nolimitmotorsport.com/wiseco/apps-Mitsubishi.html
__________________________________________________ _______________
Eclipse/ Eagle Talon 93-01 4G63 w/ 4G64 Stroker Crank - 22mm Pin
Kit Part # Bore
MM / Inch Over Sizes Stroke Rod Lgth. Comp Ht. Head cc's Dome Dish Gasket Thkness Deck Clearance Block Ht. Comp. Ratio Pin Dia. Ring # Gram Foot Notes
K596M85 85.00 / 3.346 Std. 3.937 5.905 1.130 47 -21 .042 .012 9.015 9.0 .866 8500xx 284 1
K596M855 85.50 / 3.366 .020 100 150 28.7 47 -21 1.1 0.3 229 22mm 8550xx 289 1
K596M86 86.00/3.386 .040 8600xx
1993-2004 EVO 8 w/ 4G64 stroker crank - 22mm pin (Evo 8 valve pockets opposite of 2nd gen)
Kit Part # Bore
K596M85 85.00 / 3.346 Std. 3.937 5.905 1.130 43 -21 .042 .012 9.015 9.0 .866 8500xx 1
K596M855 85.50 / 3.366 .020 100 150 28.7 43 -21 1.1 0.3 229 22mm 8550xx 1
K596M86 86.00 / 3.386 .040 8600xx
scottsee
04-28-2006, 09:45 AM
well all be damn. Thanks for posting that. Good luck
Thor06
04-28-2006, 10:57 PM
Ok, but remember, the valve pockets are opposite on the Evo pistons from the DSM pistons (even says so in the thing you copied). Not sure if it really matters, but when you are dumping several grand into an engine, I wouldnt take a chance.
SySt3mR00t
05-01-2006, 10:11 PM
Ok i didnt think that i would be back .. but i am ... MORE PROBLEMS !!!! i got my whole long block put togethor finally and i started putting on waterpump. oil pump, etc. When i got to the crankshaft sprocket, i went to put in the Crank bolt from my 4g63 into the 4g64, and the BOLT WOULD NOT THREAD UP. It wouldnt even start threading into the 4g64 block. I thought that these two bolts where supposed to be the same in the 4g63 crank and 4g64. Do i need to order a different bolt? ANY IDEAS> ANYBODY ELSE EXPERIENCE THIS ? ... PLEASE HELP !
ez1286
05-01-2006, 10:58 PM
I would just order a new cankbolt they are really cheap. Find a vin (i'm lazy) from a car with a 4g64 and i'll get the mitsu part numbe for you. My brother had to buy a new crank bolt from Mentor mitsu (an online deale i use all the time) and it was like $4.
SySt3mR00t
05-02-2006, 06:57 AM
That would be EXTREMELY HELPFUL if you could find me the part number for the crank bolt. The VIN for a Galant with a 4g64 is 4A3AJ56G7WE068386. AUTOTRADER ROCKS :) .... Still wondering why I am the only one with this problem? Has anyone else had a 4g63 crank centerbolt not thread into the 4g64 crank ? I hope my crank is not messed up.
SySt3mR00t
05-03-2006, 07:24 AM
Ok so here is the updated solution to my center crank bolt. After calling every crank manufacturer around, I got one answer... when the crank was remanufactured, the acid tank must have ate away some of the begining threading in the crank. WELL.... I go to autozone and buy a 14mm x 1.25 thread TAP tool, and the double level handle bars for the TAP at lowes. Started retapping the crank only about a centimeter into the crank. Air hosed all the debree out of the threading. Put white lithium grease on my center bolt, and started screwing it into the crank. It was tuff at first but soon as it met the original threading in the back, it was smooth as butter. FIXED MY PROBLEM!!! :)
