1994 corolla noise
paraparanoid
04-26-2006, 12:06 PM
my 1994 corolla's engine vibrates pretty harshly when it gets up to ~55 mph. Is there anything I can install to damper the vibration. Where can I find one?
kink
06-17-2006, 08:29 PM
Hi:
Your message sounds kind of like what I have been fighting with my 95 Corolla for sometime until last night when I figured it out. If it is the same problem, its the right side motor mount that need replacing. Its worn and somehow sending engine vibration to the frame. A quick check, with engine running put the end of a crowbar under the pin that goes through the motor mount and pry up. If the vibration goes away, thats it. Mine had a vibration at any rpm though. At Autozone, 40 bucks. Some of they other motor mounts may need replacment too.
