Clio 2001 power lead for an amp
dfrench79
04-26-2006, 04:36 AM
Hi, does anybody know where to put the powerlead through to the car from the battery when fitting an amp. I have a 2001 newest shape(before brand new) clio, and have no idea where it is, can anyone help???
deano1982
07-16-2006, 06:49 AM
Did you work it out? If just got the same car and im having the same problem. There are wires taped up but i just can't see where they go
deano1982
07-16-2006, 10:33 AM
Ive found the a solution apparently others have used the hole that the bonnet release cable uses. I have yet to try i found this out here: http://www.cliosport.net/forum/showthread.php?p=1789356#post1789356
ZOE2
08-16-2006, 02:58 AM
MY BROTHER WIRED UP MINE BUT THE CABLE FROM THE AMP TO THE BATTERY IS RUN INSIDE THE PLASIC COVERS THAT ARE AT THE BOTTOM OF THE CAR BELOW THE DOORS.THEY RUN FROM THE BACK TO THE FRONT INSIDE THE CAR. JUST PULL THEM SLIGHTLEY(THEY DO COME OFF) AND TUCK UR CABLE INSIDE AS YOU GO ALONG FROM BACK OF CAR TO THE FRONT AND THEN UP BY THE GLOVEBOX AND THEN THERE WILL A HOLE WHICH GOES INTO THE ENGINE AREA NEXT TO THE WATER BOTTLE.PUT IT THROUGH HOLE AND TO THE BATTERY(PASSENGER SIDE).
DOES THIS MAKE SENCE?:grinyes:
LET ME KNOW HOW YOU GET ON!
deano1982
08-16-2006, 05:48 AM
Thanks Zoe i forgot about posting here. I managed to get the cable through to the engine bay a while ago but you've reminded me that i still need to tuck the cables under the plastic.
Thanks
ZOE2
08-16-2006, 06:20 AM
Thats Cool !!
