2001 civic headlamp buzzer
brianproctorla
04-25-2006, 01:11 PM
The headlamp buzzer doesn't work on my civic. I can not find any reference to the location of the faulty components in my haynes manual
BrodyP
04-25-2006, 01:45 PM
Could be the door sensor check for oxidation. Also check the fuse.
brianproctorla
04-25-2006, 01:49 PM
The sensor is based on the key being in the ignition. I'm not sure if this runs off of a fuse. I don't know how to locate where this buzzer is
BrodyP
04-25-2006, 02:08 PM
I believe its called the door jam sensor. The warning buzz comes on when you open the drivers side door. Thats why I had suggested you check this as well as the fuse.
brianproctorla
04-25-2006, 02:10 PM
No, this is a sensor that let's you know if you've left the lights on
BrodyP
04-25-2006, 02:16 PM
I kno dude its all related. Does your dome light come on when you open your door? I just advise you to check because this had been the fix for the same issue with another person with your car.
brianproctorla
04-25-2006, 02:21 PM
Thanks.
You're right. They should run off the same system.
I think it works, but I will check it tonight.
If it doesn't work, then it's probably a fuse, correct?
BrodyP
04-25-2006, 02:30 PM
Thanks.
You got it check it out and write back.
brianproctorla
04-25-2006, 10:00 PM
You were 100% on the money. The passenger side door would actuate the dome light, but not the driver's side. I knew then that the circuit was functioning correctly. I looked at the switch itself, which is removed with one bolt/screw. The wire housing had come unplugged from the switch. I was able to fish the wire through the exposed hole after pulling off the door column panel. At this point I noticed that the plunger had become detached when the wire became uncoupled. The plunger could just be about anywhere now. I will replace the switch with a $10.00 part from autozone.
I really appreciate the help, and I'm sure everyone else who reads this in the future will be grateful as well. This was not covered in the manual at all
I owe you a beer.
-Brian
I owe you a beer.
-Brian
BrodyP
04-26-2006, 07:21 AM
:thumbsup:
