Honda 71-87 civic/crx pgmII flooding problem
ben benelli
04-24-2006, 04:14 PM
My '86 crx is flooding the cylinders with fuel. I replaced the regulater on the injector rail and have the same problem. any ideas?
lxndr
04-25-2006, 03:21 AM
You probably have an injector that is stuck open. Remove the wiring connectors from your injectors one at a time while the car is running. There should be a small change in idle as you remove each connector. If there is a big change, that's your faulty injector.
You could also have a bad ECU or injector resistor (the silver twinkie on the drivers side strut tower).
85crxzc
04-25-2006, 08:45 PM
quick question ... is it a cream filled twinkie?
lxndr
04-25-2006, 10:02 PM
Yes, but getting through the candy shell is a pain in the @$$!
