Grand AM 95 2.3 antifreeze gone
vufu
04-20-2006, 09:42 PM
Hi ,
Yesterday I've got a problem, I turned off heater and temperature started to increase up to 105 C may be just a little bit over, but much less then a red section. I stopped engine, open hood and found that antifreeze coming out through ????????? some small bent rubber hose on left side of A/C port on the passenger side of fire wall, probably heater, but I'm not sure 100%.
Can anybody tell me if there is any sort rupture disk or anything else that cause this. I didn't find any broken hoses beside.
Thanks in advance
Vufu
GTP Dad
04-21-2006, 06:19 AM
The problem is the heater core is leaking. This hose is from the heater box that is designed to send water out to the outside of the car rather than onto the floor. Pull the heater core and replace it and the problem will be fixed.
vufu
04-22-2006, 09:39 AM
Thanks GTP Dad I was thinking the same
Vufu
