95' camaro 3.4L please help
chrishedrick
04-19-2006, 09:45 PM
I have a camaro that will start and idle sometimes but when you go to give it gas it will shut off. Then other times it won't start at all just cranks over. But if you take out the 2 Injector fuses under the hood then put them back in after a minute or two it will start and run for a little while, somtimes. Im at a loss can anyone help?
97cavalier
04-19-2006, 09:54 PM
did you check spark and fuel in every cylender? and check the volts to every injector.
chrishedrick
04-19-2006, 09:58 PM
All cylinders have spark, i can't really tell if they have fuel though. they are not saturated but do smell like they are getting some fuel.
97cavalier
04-19-2006, 10:15 PM
check the fuel psi on all cylenders
CamarosRsweet94
04-19-2006, 11:15 PM
Have you run the engine for codes? That might be able to point you in the right direction. It sounds like a fuel problem to me, how long will it idle before you give it gas and kill it? Could be a bad sensor somewhere, bad fuel pump or filter. Just some guesses, get it checked for codes first.
chevy_chic20041
04-20-2006, 03:22 AM
when it doesn't start does it do anything do any lights come on or does it just do nothing?
chrishedrick
04-20-2006, 06:12 AM
I cant check for the codes because it has obd 2 but when you try to link it up it reads link error. when you turn on the key you cant hear the fuel pump charge either.
wrightz28
04-20-2006, 08:58 AM
It's not an OBD II, it a OBD I crossover hybrid.
CamarosRsweet94
04-20-2006, 09:19 AM
Could be a bad fuel pump if it isn't priming, could also be the filter though. You can check the codes because in 95 camaros had the OBD2 plugs, but still used the OBD1 code reader.
malletslinger
04-20-2006, 04:11 PM
Maybe a bad fuel pump relay?:dunno:
ViperJ
04-21-2006, 09:57 AM
When was the last time the fuel filter got changed?
