No spark on #1
exnitro
04-19-2006, 10:52 AM
I have a 92 Riv. Just had the crank position sensor replaced. I'm getting no spark on #1 coil. Tried new ignition module, same problem. Can anyone steer me in the right direction on what could be the culprit? It starts up and runs but with alternating spark on #1 coil. Thanks, Jim:mad:
maxwedge
04-19-2006, 12:39 PM
Switch coils see what happens, unless it is the unit type.
exnitro
04-19-2006, 01:10 PM
Tried that, still no spark on #1. Thinking maybe the wires from the sensor or maybe a fin bent.
maxwedge
04-19-2006, 02:01 PM
So it runs but no 1 is dead? Check for bad connections at the module, wiggle the harness at the icm, make sure you have good continuity from the ckps to the module.
exnitro
04-20-2006, 07:00 PM
Finally, got her going! It was the balancer again, fins were bent just enough to send a false signal to the puter. Thanks for the ideas.
Jim:smokin:
