disappearing oil
ROKnight
04-18-2006, 04:40 PM
well, I have a strange case of disappearing oil... The dealership filled her up to 5 qts about 2400 miles ago. My oil light recently came on and after checking levels, she was running near empty!! I checked for any under body leaks, none found, no puddles/stains under my car where I park every night, and I'm not burning oil externally due to no smoke. I filled up 4 qts and she ran well but about 700 miles in, she's rattling again. I checked the oil level and she's near empty again!! I had the dealership check for a leak and they didn't find one and there's no oil spilling on any engine components. A few days ago I put another 3 qts in but the dipstick still shows low. Any ideas of what's happening???
Thanks,
ROKnight
Thanks,
ROKnight
KimMG
04-18-2006, 06:02 PM
Take a look at the spark plugs and see if they are black and sooty. Look at the PCV system, it may be sucking the oil into the combustion chambers. How's the coolant level? Does it look like there is an excessive amount of oil in the cooling system? Check the oil level when you park and when you go to start up. Maybe someone is helping themselves by draining it out of your motor.
johnholl
04-19-2006, 11:14 AM
5 Quarts?
Also check the filter. verify that there is a gasket, and only one gasket between the filter and block
ROKnight
04-19-2006, 04:40 PM
brand new filter and 1 new seal
johnholl
04-20-2006, 11:06 AM
switch to a 10W-30 for the summer. I'll bet it's burning it. Check oil every week.
ricebike
04-20-2006, 11:59 AM
i've noticed the geo prisms are having similar oil-burning symptoms (mebbe cause they share the same type of engines???)
check pcv valve 1st...
then v-stem seals
finally leakdown test for checking piston rings...
then v-stem seals
rice(er)
04-20-2006, 01:09 PM
are you making sure you're checking the oil level when the car is cold? let it sit for a couple hours, then check.
10w-40 wouldn't hurt either ;)
ROKnight
04-20-2006, 01:35 PM
lol, I have 10w-40 in it now.. it runs beautifully with that type. I am checking the oil when it's cold too. I think I might take it back to the dealer to find what's going on. Free inspection :smokin:
