Can I wire my amp this way?
tlgpa
04-18-2006, 01:42 PM
I have a 4ch amp with line level inputs. Can I split the inputs and wire it this way?
http://img490.imageshack.us/img490/4055/amp0mq.jpg
bjboertje
04-18-2006, 01:48 PM
i cant see your pic (public computer with image filters), but generally you wouldn't want to split inputs.
PaulD
04-18-2006, 10:03 PM
that would be fine but I am not sure what you are trying to do. Does the amp have a built in crossover ?
tlgpa
04-19-2006, 08:16 AM
that would be fine but I am not sure what you are trying to do. Does the amp have a built in crossover ? I'd like to use the amp to power my rear speakers and a sub, without having to run separate wires all the way from the dash.
Yes the amp has a built in crossover.
PaulD
04-19-2006, 06:29 PM
then you are in luck, you can run just 1 set of RCA cables to the back. Then use the amps crossover to supply the other input. Read thru the manual and it will show you how to do it.
