Help!! Cannot Move Car
Chris_0908
04-17-2006, 10:47 PM
Ok here's the deal. I went out saw some people, did what i had to do. Get in my car and I have no pressure on my clutch pedel. I check the clutch master cylinder and it was bone dry. so I add brake fluid, and pump the clutch and still nothing. It's a 2003 Eclipse GS. I don't beat on it, and I've only had the car for a month and put 8,000 miles on it. I bought it from a dealership and got the extended warrenty. If someone can help me so I can get this car out o where it is, it would help
Thor06
04-17-2006, 10:54 PM
You should have put this in the Eclipse 2000+ section...
Is the clutch pedal hooked up right? Is it in a spot you can work in it? You could get it towed to a shop or you could rent a tow dolly.
blk_srt
04-17-2006, 11:07 PM
Thor is right, wrong section. But you cant just add fluid to a dry line and expect it to work right, you have to bleed it if ANY air got in the system. And more importnatly figure out what happened to all of the fluid in the first place
Blackcrow64
04-17-2006, 11:11 PM
He said he pushed the clutch in and had no pressure, so I'm sure that sucked plenty of air into the line... That'll be fun to take apart and bleed again on a 2000+ model. :thumbsup:
Turbodog97
04-17-2006, 11:51 PM
Happened to my '95...had to replace the master cylinder and bleed the lines and etc.
gthompson97
04-18-2006, 12:30 AM
If you got the extended warranty, why don't you just bring the damn thing in?
