wastegate help
blk_srt
04-17-2006, 07:28 PM
I have a ported s16g and the wastegate vacuum line keeps getting pinched off by my intake causing the mbc to fail. My question is has anyone else had the problem, if so how did you fix it. Second what would I need to max out the 16g as far as supporting mods, I have 550s and soon I'll get a 190. Will that be enough? And i figure the stock head gasket will hold ~20psi with the arps that are in it, is that close?
Blackcrow64
04-17-2006, 07:35 PM
From what I've been told, ARP's with an oem headgasket will take a good bit of abuse.
blk_srt
04-17-2006, 09:28 PM
any ideas on the wastegate?
Thor06
04-17-2006, 10:09 PM
Maybe zip tie a pencil or something to it to keep it straight?
blk_srt
04-17-2006, 10:14 PM
well I don't know if its the same way one a b16g, but on a s16g the nipple points straight up(:lol:) almost directly into the intake tube. Is there any way to actually rotate the actuator so the nipple points another direction?
crunchymilk55
04-17-2006, 10:23 PM
yep, a local hadthe same issue, he rotated the actuator arm somehow,ill ask
blk_srt
04-17-2006, 11:28 PM
sweet
Blackcrow64
04-17-2006, 11:30 PM
Actually,that is something I noticed too when I had it... I wondered how the hell it was supposed to avoid the intake. As far as I could tell there was no way to move it. Perhaps you could make some type of silicon 90 bend?
blk_srt
04-18-2006, 08:09 PM
ok, today I found something that should work perfect. I got a hard vacuum line off of an egr valve from a 3100series gm motor and it has a 90* bend on one end
Blackcrow64
04-19-2006, 01:08 AM
:thumbsup:
:thumbsup:
