Window down in rain and snow! HELP!
L8DBUGG
04-16-2006, 12:48 AM
Please help!......I have a 02 Chev Cavalier and my driver's side window will let down, but when I try to let it up, it goes up a little and then stops. It takes a very long time to go up and whenever I push the "up" button, it goes up a little and stops. In the rain, I ride down the street pressing the "up" button until it eventually closes. What is causing this? Is there a part that I can buy and if so, where does it go?? :mad:
jakegday
04-16-2006, 12:06 PM
either something is pressing agaisnt the window causing friction (inside the door) or your motor is going bad and you'll need to replace it soon (also inside the door)
Cold_Silence
04-16-2006, 08:28 PM
Yeah its most likely the motor, im not sure if its called the same for power windows it could be the "window regulator" or just the window motor its called. A slim chance it could be the wiring, but possible, damaged wire etc.
ponchonutty
04-16-2006, 08:38 PM
My guess would be the cheap window regulator. My pass. side window was going real slow in my Silverado. So, I tried to force it up and then it completely broke! $275 for a new one with me replacing it.
