98 cavalier with ecu problems.
alphaglobe
04-12-2006, 04:23 PM
i have a 98 cavalier with a 2.4 engine and have an intermitten problem with rough idle the mechanick says its the ecu. can i replace it with a used one without reprogramming the ecu at the dealer.
4dr92cavi4cyl
04-13-2006, 02:55 PM
Clean your IAC (Idle Air Control) valve, do a search for IAC and you'll find at least 50 threads on this topic. It's very easy to do and is more than likely causing the problem.
alphaglobe
04-13-2006, 06:30 PM
tks i will try that !:smooch:
alphaglobe
04-13-2006, 06:34 PM
also if it is the ECU can we buy one and just plug it in or it needs to be remaped at the dealer?
boarder_punk
04-13-2006, 06:50 PM
I would also suggest checking the EGR, MAP, and MAF (or whatever airflow sensor it uses).
jakegday
04-13-2006, 07:22 PM
yes, IF the problem is your ecu you will need to have it "remaped"
4dr92cavi4cyl
04-14-2006, 10:57 AM
I really doubt it's the ECU, if something was fried in the ECU, a rough idle would be the least of your problems... I could be wrong, but I doubt it's the ECU.
