95 Bonny, brake troubles
jusber15
04-12-2006, 05:07 PM
I have a 95 bonneville with ABS. When I come to a stop and maintain brake pressure on the pedal, it slowly continues to travel down...as if a small leak somewhere. I put it in the garage and followed just about every inch of lines with no leaks and I have no fluid loss. Whatcha think??
auto trainy
04-12-2006, 07:16 PM
Sounds like a master cylinder or air but I'll go wth the master cylinder,I would also check all the wheel cylinders and calibers w/the wheels off and drums off just to be sure,good luck.
richtazz
04-13-2006, 06:36 PM
I agree with auto, a sinking pedal with no external leaks or fluid loss is a bad master cylinder.
sixsmiles
04-14-2006, 09:06 AM
Had exact same problem on my 95 and it was the Master Cylinder.
jusber15
04-14-2006, 10:29 AM
Thanks for the advice. Replaced the master cylinder and all is well! Thanks once again! :)
