Transmission Upgrade
studious03
04-11-2006, 06:43 PM
Noticing a little slip during shifts even after fluid and filter change. Just wondering if i were to go with the 700r4 tranny is it as simple as plug-n-play with the install?
silicon212
04-11-2006, 07:27 PM
It's not quite plug and play if you have a 2004R. You will need to replace your crossmember and your driveshaft. The 700R4 is a little longer (about 2 inches) than the 2004R, and the transmission mount is closer to the pan (TH350 style vs. TH400 style on the 2004R). The dipstick tube will also need to be for a TH700R4. Aside from that, it's fairly straightforward. You can use your current TV cable, and the TCC cable is the same on both.
If you have a '4L60', then you need do nothing. You already have a TH700R4.
studious03
04-11-2006, 08:09 PM
once again thank you silicon212! another question has anyone else tried this? the new crossmember i can get from??? and last but not least, i noticed that engine temp tends to go up and down, (not overheating) USUALLY down when driving, i was told that this was because of the tranny in some way?
studious03
04-11-2006, 08:13 PM
another question i forgot! how do i tell which tranny i currently have?:newbie:
Blue Bowtie
04-11-2006, 09:11 PM
In a '92 Caprice, you should have a TH700-R4. A '93 may have a 4L60 (not "E" variant). It's a slight revision of the TH700-R4, but a 700 will bolt right in it's place. Thankfully (and finally) the regrettable TH200C-R4 was dropped in 1989, so you're safe. Fortunately, the '85 wagon I had was equipped with the 700, since it needed to do real work.
You can verify the type by the oil pan pattern:
http://72.19.213.157/files/TransPanID.jpg
If you're shopping for a replacement, get something newer than 1986. There were a couple enhancements made during the '86 model year, and '87 and up 700s were all 10-vane pumps, had the auxilliary valve body, and had the improved 30-spline input shaft. Don't cheap out, either. You need to replace the torque converter with the transmission.
DenisM
04-12-2006, 09:31 PM
Would the crossmember have to be different altogether, or could it just be moved? going from the 200-4r to the 700-r4, would the crossmember and driveshaft be the only issue, or would the torque converter and flywheel be an issue also?
silicon212
04-12-2006, 10:12 PM
Flywheel is not an issue - but the TC definitely is. You must use the torque converter for your transmission (if a 2004R then a TC for a 2004R, if a 27-spline 700R4 you can use the 27-spline or the 2004R TC, if a 30-spline you must use a 30-spline 700R4 TC).
BB - the 700R4 became the 4L60 in 1987 - not 1993. They have the aux valve body.
Blue Bowtie
04-13-2006, 10:42 AM
Strange, isn't it? In F-bodies it was still called "TH700-R4" through 1992. At least that's what's in the Helm's manual. Semantics - Go figure. You're right, though, since the ATSG manual calls it a "4l60" for whatever it's installed under.
No matter. At least he has the good transmission, either way.
silicon212
04-13-2006, 10:47 AM
My take is that the late-model GM nomenclature wasn't 'enforced' until around '92-'93. Back in '90, someone gave me a 'slightly used, 2-year old 3L80' transmission. Of course at the time I didn't know what that was, but was surprised when I went to go get it that it was a TH400!
