94 mark VIII starts and idles but stall's when u give it gas
loaderman
04-09-2006, 01:30 PM
it starts and idles but stall's when u give it gas, i check the fuel pressure its at 42 psi and stays there over night!
paul_meets_mark
04-22-2006, 09:29 PM
You should start looking at your vacuum lines, perhaps your EGR valve, and other components around your intake. Thats a start.
MagicRat
04-23-2006, 05:17 PM
It sounds like a bad throttle position sensor.
Old Tinker
08-01-2006, 04:15 PM
May want to check the pressure regulator.
Marked
08-06-2006, 10:03 PM
Did you check Fuel pressure with the Vacuum hose off, or on?
It should be checked with the hose off, and it should be at around 32psi, IIRC.
