90 maxima dash cluster problem
yogie323
04-09-2006, 12:57 PM
Has anybody had this problem on a 1990 maxima? The lights on the cluster will not turn on I have to let the temperature rise to certain degrees and then they turn on, it's starts to be a pain in the ass when there is times that I can’t warm up the car like when I'm running late minutes later the lights turn on.
Does anybody know what part or sensor is causing this?
:banghead:
Nahkapohjola
04-09-2006, 01:54 PM
Seems like oxidation/harness/connector/fuse problem(s). Check charge voltage, start cleaning connectors inspecting wirings.
Real lamp assy supply is behind same fuses: take rear lamp assemblys off on the table and inspect for short circuits. Fuses: Page5, see link below,
