1995 Suburban Brake Problem
kess4667
04-08-2006, 08:09 PM
I just changed my rotors and calipers. Now the drivers side rotor is grinding against the a-arm. I took everything apart and put it back together and still the same problem. Any ideas on what is causing this? Thanks for your input.
Mike
horse482
04-10-2006, 01:55 PM
Take both rotors of the truck, lay them flat on the ground and measure to the top of the brake rotor at the hub, then see if they are the same between the two, also the same as the old ones (there will be a little bit of difference because of ware on the old rotors. If they are the same you have a different problem, check to see if something is stuck on the hub or the back of the rotor where it contacts the hub. If you still not sure what the measurement should be post me back, need to know 1/2 or 3/4 ton, 2x4 or 4x4.
