AIR DRIED BEEF DOG FOOD
GReddy rs leaking? how to tune?
TreeFrog
04-08-2006, 06:32 AM
okay i'm not sure if my GReddy type-RS is leaking or creating compressor surge. the problem is i don't have a boost gauge yet, so i can't tell.
I've searched all around and i've read what sounds i should be looking for. BOV blowing off under full boost, and turkey gobble under low throtal for compressor surge.
okay under low throtal i get a slight whistle, that sounds like a bird. I thought this was compressor surge so i lossened it about 5 turns, and i stil get the same exact sound.
under full boost i get the same shhhhhhh suction sound i got with stock bov. I started to get this suction sound after my intake, so i always assumed it was the intake. but i'm not sure.
not too many turbo cars around here... so no one to get in my car and listen.
plese help!
defiancy
04-08-2006, 04:05 PM
plese help!
I think with the RS you can still do the single spring mod. I was having problems with my Type-S BOV and I did the single spring mod and it fixed it, and made it more adjustable.
blk_srt
04-08-2006, 04:09 PM
:Iagree: Take it apart and only use the heavier spring and it will work better
crunchymilk55
04-09-2006, 02:50 AM
well I have the RS and have never had to deal with what you're talking about, but here is what I like to do to all greddy BOV's
loosen the fucker almost all the way, blow off around full boost, then blow off around mid boost. Then tighten it half a turn and do this again. Keep doing it until you hear a "gobble" at mid boost. Then turn it back half a turn to where it didn't do this. This is the tighest spring you can have without it not opening fully. No boost gauge will make things a BIT tougher, but you know when your turbo is full spooled, and you know when it's about halfway done.
TreeFrog
04-09-2006, 07:16 AM
well i noticed today that the suction sounds STOPS at 4k rmps instantly, and all i hear is vroooom. basicly once turbo is spooled suction sound stops. so its not the bov leaking off at full boost...
TreeFrog
04-11-2006, 12:17 PM
okay its fixed... sorta!
I took some advice and tightened the bov. now no more suction sound!!! it was leaking, same as stock sound. so stock was leaking.
i just test drove it. the sound is 90% gone. :)
my bov sound has a slight chirp or whistle now. i get no surge sound like cha cha cha turkey call. should i tighten more until i get that surge sound, then loosen just until i don't?
clipsekid99
04-11-2006, 12:35 PM
http://www.dsmtuners.com/forums/showthread.php?t=215994&highlight=how+to+tune+greddy+type+s+bov
I would guess it's the same for the type rs.
TreeFrog
04-11-2006, 01:42 PM
wow that helps a lot!! thanks
so i want it soft as possible with out blowing off under boost... i should try and loosen it a little. just to where it can hold the pressure. basicly a gauge would help this
but right now i think its pretty good. no flutter that i can tell, and its not blowing off under boost
i feel like i added 30hp is 30 secs. its not leaking now, and i think i just gave my self whiplash.
clipsekid99
04-11-2006, 02:10 PM
Haha, no prob man, glad to help.
crunchymilk55
04-11-2006, 05:24 PM
read my last post again...works everytime
