junk yard engines
85crxzc
04-07-2006, 06:18 PM
ok so im lookin for a new engine for my crx and i came across 1 at the local junkyard so i picked it up for 400 bucks... but when i got home i did a compression test on it and only the first cylinder had compression the rest were like only 10psi. so i called them up cussed them out and got me another motor this time they promised it had compression... but the dam thing didnt. then a buddy had suggested that if it had sat for a long period of time then the rings would'nt seal properly and that i should add a little oil to the cylinders and redo the test..so i did and all but 1 cylinder cam up and when im doing the test i can see the compressed air coming out of the exhast ports except the 1 dead cylinder i cant see or feel any air being rushed past any open or burned valves or nowhere... hopefully a bad headgaskets the cause there
so i guess my question is could an engine really loose the seal between the rings and wall if let sit lets say a year or so??? and the compression only be like 15psi the skyrocket to 180 when the oil is added
also if i let the #2 cylinder built its top compression it reaches like 240psi is that normal because the highest compression i got off the ther 2 where 180.......
any help or ideas would b apreciated .... and sorry for al the questions and me sounding ignorent lol:rofl:
superbluecivicsi
04-07-2006, 11:52 PM
you are doing the compression test with the longblock in the car at normal operating temps?
what does your leakdown say?
85crxzc
04-08-2006, 01:00 PM
thats the thing the engine wont run thats what i mean on doing a compression test on a engine thats sat for a while... no i didnt do a leak down how do i to that?? the compression tester has a valve stem in it to hold the compression in. lol im clueless
superbluecivicsi
04-08-2006, 02:10 PM
the inconsistent readings are due to the engine being cold. do a leak down.
http://www.c-speedracing.com/howto/leakdown/leakdown.php
superbluecivicsi
04-08-2006, 02:11 PM
PS: the junk yard will not do the leakdown for you prior to purchasing the block?
85crxzc
04-08-2006, 05:07 PM
very cool info ill see if i can pick up a leakdown test and see what kinda results i can get.. also with this second engine i havent installed it in the car cuz i wanted to make sure it had compression and a mechanic friend told me that all i had to do was connect a tranny and starter to the long block on the ground to do it...so i did . dont laugh if that sounds wack i just do what plp tell me to.. and so the first reading didnt have any so i added oil then all but 1 cylinder came up... ill see if i can get ahold of that tool today and ill post back...
superbluecivicsi
04-08-2006, 07:44 PM
you can do that too. id prefer the leakdown.
85crxzc
04-08-2006, 08:40 PM
well im starting to loose interest with doing my engine swap now due to all the dam bad luck ive encountered so now im gonna go to a local pick n pull and source out a stock short block to replace my old 1 that spun a rod bearing... slowly ill invest the time to find the source of problem with this motor and do a rebuild on it..... ive learned a lesson not to deal with my local auto wrecker .... they burned me twice . not ever again though
