95 tracker fumes
TamieK
04-06-2006, 09:26 PM
I bought a 95 tracker off ebay in February. Runs great and fun to drive. Put O2 sensor in for inspection. Mechanic told me put a cat on it, doing that the end of month. My question is when going down hills I get fumes. Could this be because of the cat? Thanks.
viperh
04-08-2006, 05:50 AM
could be.. is there any funes in the engine bay when its at operating temprature? Ebay has some cats on there. I bought one from SSautochrome or something like that.. Its cheap so dont expect it to last forever.heres a link 60 bucks.. alot cheaper than buying one from a smog place or a dealership.
Do you have to pass a sniffer test or just a visual inspection?
http://cgi.ebay.com/ebaymotors/MAGNAFLOW-Catalytic-Converter-Car-Sound-High-Flow-94109_W0QQcmdZViewItemQQcategoryZ33629QQitemZ79505 79561QQrdZ1QQsspagenameZWD1V
TamieK
04-08-2006, 07:41 PM
Had to go through the sniffer test. The only time I smell the fumes is when I'm going down a hill. None when sitting idling and I didn't notice any outside when it was running with the hood up if that's what you mean. It does have a slight miss when idling that they noticed at the garage.
viperh
04-09-2006, 09:37 AM
probably just a lack of CAT for the fumes.. E-mail the seller on EBAY if they will pass your states smog. I believe thay will pass california will def pass federal emissions. (you may have to advance or retard your timing a little. It also helps to burn 91-93 octane fuel burns cleaner.)
