ABS Controler
9934alero
04-05-2006, 07:20 PM
My ABS and brake lights came on on my dash, so i went and got it hooked up to the diagnostic computer. I was told the problem was that my ABS Controler is bad. Has any one had this go on them? just looking for advice for replacement. I was quoted $1300 CAD parts and labour. Thanks in advance for you imput
-Trav
BNaylor
04-05-2006, 11:41 PM
$1300 CAD. Ouch! Was that for the ABS motor/modulator or the ABS & Traction Control Module (EBTCM)? What were the ABS fault codes?
9934alero
04-06-2006, 02:20 PM
i belive it is the trac control modulator. i'm not sure on the fault codes, but i know that it is the part that all the brake lines run through. the part is 1000 dollars, and from what i know, is only available through the dealer.
