Bouncy Bouncy Bounce!!!!!!!!!
GSXracerGuy
04-05-2006, 01:29 PM
Yall know my car.
Anyway I forgot to write about something in my last posting thing.
Let's say we are crusin down mainstreet in 2nd gear goin ehhh 30 mph. The turbo is at a good place to kick in...so...I floor it..the car bounces as if it's sputtering almost...like the car will go forward hard with the power..and then back off...3 times quickly in like 1 second. Then after that clears up..THEN it accelerates fine.
Is this the MAS?? I checked the wiring and it is fine.
Blackcrow64
04-05-2006, 04:56 PM
Sounds like a MAS problem... Maybe the sensor itself has gone bad.
GSXracerGuy
04-05-2006, 05:06 PM
anyone have an extra MAS lyin around?
Blackcrow64
04-05-2006, 05:13 PM
Actually, I have that entire pipe from the filter to the turbo that I no longer need. Got a nice little k&n filter on it too. lol
crunchymilk55
04-05-2006, 05:24 PM
plugs / wires, sounds like you're losing spark
GSXracerGuy
04-05-2006, 06:14 PM
Blackcrow...how much do you want for it?
l_eclipse_l
04-05-2006, 06:23 PM
I second this.
I second this.
Blackcrow64
04-05-2006, 09:50 PM
125 shipped for the whole thing... But you should check and see if its the plugs and wires first like the others said before buying this. Plugs and wires would be way cheaper to possibly solve that problem. :)
scottsee
04-05-2006, 10:04 PM
I second this.
Tripple this
Tripple this
GSXracerGuy
04-05-2006, 10:10 PM
well I looked at it and all of the wires are fine..separated...attached correctl etc..is there anything else I am supposed to check??
showstopperz
04-05-2006, 10:17 PM
:iagree:
i am not a mechanic but my spyder did the same thing . i changed my plugs and wires now it works fine!! IMO that was a good call!!:bigthumb:
:iagree:
defiancy
04-05-2006, 10:37 PM
At bare minimun replace the plugs, when you do make sure they are gapped correctly.
GSXracerGuy
04-05-2006, 11:12 PM
the spark plugs? Doesn't the spark only affect start up?
defiancy
04-05-2006, 11:18 PM
I will not give you a smart comment instead I will give you a nice answer.
Spark is what ignites the fuel inside the cylinders. In order for the car to run you have to have good spark. No spark no boom. The car runs on gas, that gas has to be ignited some how, hence the spark plugs.
If you require a more detailed understanding of how a combustion engine works I will gladly find a link for you.
If you are having hesitation it sounds like it could be that your spark plugs are going bad.
clipsekid99
04-05-2006, 11:21 PM
:spit:
:spit:
l_eclipse_l
04-05-2006, 11:31 PM
Ignoring your later comment...
Make sure the wires don't have cracks. Pull the plugs and look at the tips. If they are all corroded, this is most likely your problem. Replace them with NGK and gap them accordingly.
crunchymilk55
04-06-2006, 12:08 AM
trying.....so....hard.....not......to.....be.....a n....asshole.......
must....remember....everyone.....starts....somewhe re.....
:banghead: :banghead: :banghead: :banghead: :banghead: :banghead:
AHHHHHHHHH!!
AHHHHHHHHH!!
crunchymilk55
04-06-2006, 12:10 AM
I'm OK...I'm OK...almost didn't make it through that..
take your car to any mechanic and them you want your spark plugs replaced. tell them you only want NGK BPR6ES gapped at .028. shouldn't be more than 30 bucks. It will fix your problem.
defiancy
04-06-2006, 10:38 AM
I had a real hard time resisting myself.
EDMUND65
04-06-2006, 10:46 AM
u guys are nuts
GSXracerGuy
04-06-2006, 11:55 AM
OK I realize that was a stupid question. BUT...I know a spark ignites the fuel in the engine..but I figured once the combustion was going...it didn't need to be restarted...but now that I think of it..if it combusts...the fuel is gone..it needs a new spark to restart the process.. But that occuring dozens of times per second..I didn't think of it being able to happen that fast
nova1313
04-06-2006, 12:19 PM
hey my spyder gst does the same thing. Seems to try to go but it can't right around 3k where the turbo kicks in. But mine only does it when it's cold. It started happening about 2 weeks after I put an open air filter on my car.
defiancy
04-06-2006, 01:11 PM
Yep that is a combustion engine for you.
