Paint
18Visions
07-11-2002, 04:52 PM
When you guys paint your bodies, what kinda of sprays do you use? tamiya spray paints? I dont want to airbrush. I was on tamiya's web page and am wondering what paints to buy to paint the body on my tamiya opel astra kit. any links would help.
rcmaxx
07-11-2002, 05:00 PM
view the paint sheet on you instruction, its says what color you need for the body. they are all tamiya colors.
18Visions
07-11-2002, 05:48 PM
but I mean which kinds of paint, I know the color sheet. But im refering to whats the paint called. I dont want to airbrush I want to buy the sprays. Likes the name of the spray cans? "tamiya automotive spras?
daggerlee
07-11-2002, 06:01 PM
They're called Tamiya Sprays, they are round cylinders with color-coded caps wrapped in plastic with stickers on them telling you what color it is
18Visions
07-11-2002, 06:37 PM
TAM85016 TS-16 Spray Lacquer Yellow that the stuff there?
rcmaxx
you're hobby shop should have it. They are just like what was described and the paint is in the tops color.
18Visions
07-15-2002, 04:28 PM
how about decals, what kind of methods do you guys prefer? Im about to start my first model car and I belive with the proper research from this forum, I can make it look awsome. Another question. Would the average model shop have car model primer? For instance does tamiya actually make a primer for models? Where do you guys buy your primer.
- Thanks in advance, Mitch
primera man
07-15-2002, 08:31 PM
Have a good read through here if you have not seen it yet
http://www.automotiveforums.com/vbulletin/t45619.html .....
Sob
07-15-2002, 11:09 PM
Hey there 18Visions. For primer, I just use automotive primer. You can get that usually at any automotive store. It's Dupi-color and it comes in grey or white. Use the white for lighter colors, just to make sure the grey color doesn't bleed through. (although I've never had any problems with the grey bleeding through) What you also should get while you're at the automotive store is some fine grit sandpaper, like 1500 and 2000 grit. Get your car body all primered up and then sand it to a smooth, glass like finish. Then repeat. I usually do 4 coats of primer. But that all depends on how much you want to do, personal preferences, all that. And when you're done with the primer WAIT a couple of days. The primer needs to "gas out", and it will wreck your paint job if you do it too soon.
Hope some of this babble will help ya, and welcome! This is a really great place for info, and I'm new here also! Peace out.
18Visions
07-16-2002, 12:25 PM
yes ive read all the tutorials/faqs in here. But what im really asking is this. Primea man. On your opel astra, what kind of primer did you buy, like what brand/make/which store. Is what im asking. Also did you use the exact colors from the tamiya manual? And you used just the normal tamiya sprays correct? I'm basically just looking for exact product names/stores you buy them from.
COZMO6476
07-16-2002, 01:08 PM
18visions
Tamiya makes everything you need to make their models. primer, sand paper, polishing compound... you name it, they have it. but like anything out there, they have competition from other companies. many people prefer not using the some of the tamiya products for a variety of reasons. they mainly stick to a method that works for them through trial and error. I hate to say it but you will learn alot from the first model you make. and chances are you will make mistakes, but thats the way you learn. if you have a hobby shop around you take a good stroll through the place to see exactly what they carry. they may have some tamiya products but they may not carry them all. for instance, the shop i go to does not carry tamiya primer, glues, sand papers, or compound. I either go to another shop further away or i order them online. its all about experience. you'll need some skill to make models but to really make great models, you can do it without experience. Hope that helps. Have fun!
rcmaxx
07-16-2002, 01:30 PM
getting the exact products most people use wont get wont make you a better modeler. You Can use Tamiya Primer, It coems in gray and white. I suggest using white for light color not because gray will bleed, it wont, it will darker your color. Some of us are smart and get different shades of one paint by using different primers.
I suggest you look in the Paint chart, everything thats there should be carried by your hobby shop, the TS-## are spray cans and the X-## are little bottles(they are all tamiya). Testors paints are also good as long as you stick with enamel. you dont HAVE to get all the colors in the book, My first modelw as done with ONE black, ONE Silver. nowdays I use Flat Black, Satin Black, Semi Gloss Black, Rubber Black. allumnium, silver, chrome, gunmetal.......but for a first car I dont think thats required.
if you want you can use Automtive primers, there are hundreds of brands, I have no idea where you are so I dont know what brands you have.
18Visions
07-16-2002, 05:12 PM
OK! great someone hit the nail on the head. All I needed to know was where to shop for primer (and you answered that). Thanks a ton! I have a pretty extensive modeling shope so i hope they have the primer. As for the sanding, I have a belt sander so im ok there. LOL... canadian tire should stock the wet/low grade papers. Thanks a ton fellas
PS: if it comes down to it where do you order your model Primer from.
18Visions
07-16-2002, 05:31 PM
I used to build a ton of military armour models when I was 11-13 Im 21 now.... So hopefully I still have some skill left in me. Thanks alot for all the info I have a amazing digital camera so I will hopefully have some perdy pictures in a month. Does anyone know if anyone makes a good modern police car model? Be kind of neat to added behind some model cars for a diaroma feel.
Jay!
07-16-2002, 07:14 PM
Originally posted by 18Visions
Does anyone know if anyone makes a good modern police car model? Be kind of neat to added behind some model cars for a diaroma feel. There are a few: snap plastic kits, metal-body kits, and at least one complete 1/24 metal pre-assembled cars. The recent ones are almost all Crown Vics with various markings. (I like the CHP ones... ;))
daggerlee
07-16-2002, 07:59 PM
http://www.hlj.com/images/aos/aos23907box.gif
http://www.hlj.com/images/fuj/fuj18416box.gif
Just search for "police" at www.hlj.com
rcmaxx
07-16-2002, 08:12 PM
what cars do they use for Police cars in japan?
Jay!
07-16-2002, 08:20 PM
http://www.policecars.f9.co.uk/abroad/japan.htm
http://www.squadpix.com/inter/japan.html
http://zhome.com/History/432Z2.htm
http://www.iee.et.tu-dresden.de/~henker/images_japan/large/policar.jpg
http://aris.ss.uci.edu/rgarfias/japan99/02osakapolice.jpg
rcmaxx
07-16-2002, 09:34 PM
thanks, so the Rx-7 and the Late Model Skylines are just models right? no real thing?
Is'nt there a Model of the 240z police car?
18Visions
07-17-2002, 06:49 PM
I supose if you screwed up a model and where into military models. you could trash it and add it to a diaroma with some military soliders hiding behind it or shooting over it.
hirofkd
07-17-2002, 07:13 PM
They are real things. :)
http://www.ne.jp/asahi/rjoo/area88/zukan/zukan.htm
And I think Fujimi has the 240z Police version.
rcmaxx
07-17-2002, 07:38 PM
holy mother of jebus!!!!!! damn, holy crap! a r34 police car, how much are the skylines in japan? also, the polices cars in japan look REAL RICEY! ex. really high lights, little gold sings, Mirrors that stand out, lots of Japanese letter stickers........lol, just kidding, but what are those plastic/glass things in the windshield? looks like something to aim their lazers or something.
primera man
07-17-2002, 08:10 PM
lol...pretty much "game over" seeing a R34 in you rear veiw mirrors :eek:
daggerlee
07-17-2002, 08:22 PM
Aoshima also makes a 240Z police cruiser, just search for "police" at www.hlj.com
