92' Tracker
mcspidy
04-03-2006, 01:26 PM
I purchased a 92' Geo Tracker 1.6 4x4 Automatic from a friend with the vacuum and coolant lines removed from the back of the engine. Chilton does not give a very good example of where these lines should go. The only vacuum line remaining off is from the top of the transmission while the only coolant line is a 3/8" diameter hose that looks to connect to the throttle body. Any Ideas, diagrams, pictures etc?
Thanks
Thanks
viperh
04-03-2006, 02:24 PM
Thanks
if it is from the back of the engine check to see if your heater core is connected.. Your friend may have disconnected it because the heater core was leaking. :2cents:
Thanks
mcspidy
04-05-2006, 07:15 AM
Thanks, the coolant line came from an elbow connector on the left of the throttle body while the vacuum lines are actually vent lines to keep water out of the transmission.
