rear end question
iroczman
03-31-2006, 01:41 PM
Does anybody know what size rear end my car has? It is a 89 lb9 iroc with 700-r4 and the axle code is 6ht with 2.73 to 1 and posi. I'm trying to figure it out because i am wanting to get a rear drum to disc brake conversion kit. i am looking at one in summit and i dont know exactly what to get.
it is http://store.summitracing.com/partdetail.asp?autofilter=1&part=SSB%2DA125%2D3&N=0&autoview=sku
Elk
03-31-2006, 02:19 PM
I'm pretty sure your Camaro has a GM 10-bolt.
AFI 05
03-31-2006, 02:50 PM
i think up to 89.. they got the 9 bolt BW.. the aussie rear end.. not 100% sure tho.. and from 90+ they got 10 bolts again.. someone correct me if im wrong..
Elk
03-31-2006, 06:18 PM
Well all he has to do is count the bolts on the diff cover.
HotZ28
03-31-2006, 07:59 PM
The Aussie 9-bolt was an option used in the B4E option and performance axle ratio cars with a 2.73 & 3.27 ratio. This option used the 7 5/8" ring gear, not a 7 1/2" used with the 10 bolt. Look at the rear cover and count the bolts on the cover, or look for a rubber fill plug on the rear cover, which would indicate a 9-bolt rear. I used a rear disc conversion from a 89 IROC 9-bolt, to upgrade an 87 9-bolt with the old ratchet style caliper. The 89 had larger disc and the hydrulic parking brake in leiu of the manual ratchet.
iroczman
04-03-2006, 01:58 PM
well how do i find out if my rearend is 7.5 or 7.3/4?
i belive it is a 10 bolt.
wrightz28
04-03-2006, 02:04 PM
Look at the rear cover and count the bolts on the cover, .
This determines? :dunno:
Elk
04-03-2006, 05:20 PM
It’s 7.5 or 7 5/8 and you measure the ring gear, but it only matters if your buying gears. Everything except gears are the same on a GM 10 bolt 7.5 as a 7 5/8 axle.
If you want to be sure of what axle your Camaro has jack up the back of the car and look at the diff cover.
http://www.powertrax.com/differential.html
This determines?
9 bolts on the cover = 9 bolt axle. 10 bolts = 10 bolt axle. Etc, etc.
Jcrane88
04-03-2006, 07:03 PM
im pretty sure you have the 7.5" ring gear..they didnt use the 7.625 (7 5/8) until later i beleive
Jcrane88
04-03-2006, 07:07 PM
also..for 1988 and 1989 for him to have the borg warner rear he needs axle codes GH3 GW6 or GM3
blindeyed
04-04-2006, 04:45 AM
That's alot of money for a rear disc conversion. Have you tried looking at any junk yards or ebay by any chance?
wrightz28
04-04-2006, 09:09 AM
Um, the number of bolts that hold the cover on don't have a thing to with 9 or 10 bolt.
9 or 10 bolts is how many attatch the ring gear itself in for rigidity.
Elk
04-04-2006, 01:35 PM
The Aussie 9-bolt axle has a 9 bolt cover, a GM 10 bolt axle has a 10 bolt cover, a GM 12 bolt axle has a 12 bolt cover and a GM 14 bolt axle has a 14 bolt cover.
With GM axles you can figure out how many bolts are on the ring gear by counting the number of bolts on the cover.
If you don’t believe me hear is link with a picture of a Aussie 9-bolt and GM 14 bolt count the number of bolts on the covers:
http://www.taperformance.com/rearend.htm
wrightz28
04-04-2006, 01:50 PM
Well, that may be a strange occurance amongst GMs I haven't picked up on, but in general rule of thumb, counting the number of bolts for the cover has nothing to do with the ring gear bolts.
