2001 Blazer new plugs & wires?!
thorbergdt
03-29-2006, 02:48 PM
Hey All im at the 77,xxx mile mark.. and im considering some new plugs and wires anyone got a good recommendation? I don't want to go too crazy with the price and I use the vehicle primarily for carting around town, i pull a boat twice a year so not to much strain is on it. Thanks for the comments
2000blazerls
03-29-2006, 03:11 PM
I used the AC Delco Plats (I think you have to use them) but I went with Taylor Performance Wires (in red) intead of stock replacement. I am very happy with both. I got both items from Carquest. Paid like $100 for the wires and about $3 each on the plugs but that was with my discount from my job. I am not sure what list is on them. Make sure you read the how to provided in this forum on that one pain in the ass plug to get it out easily.
thorbergdt
03-29-2006, 03:19 PM
Any recommendations to get the whole bang for say under 100$ ? perhaps a website even?
2000blazerls
03-29-2006, 04:11 PM
Well you can go cheap on the wires. Advanced Auto or Pep Boys will probably be able to get the wires cheap (a no name non performance style) but you should stick with the AC Delco plats. Double check your gap when you get them too. 2 out of the 6 were gapped wrong when I got mine.
thorbergdt
03-29-2006, 04:18 PM
So by no means should I get any other name brand Plugs? I was looking at some for like 4$ each, they are Bosch Platinum 2 Plugs. Seen on that link as the 4th one down http://replacement.autopartswarehouse.com/parts/autopartswarehouse/wizard.jsp?year=2001&make=CV&model=BLAZ-4{embeddash}DOOR-006&category=All∂=Spark%20Plug&dp=true (http://replacement.autopartswarehouse.com/parts/autopartswarehouse/wizard.jsp?year=2001&make=CV&model=BLAZ-4%7Bembeddash%7DDOOR-006&category=All&part=Spark%20Plug&dp=true)
I was also looking at getting these wires, made by JBA.
http://www.autopartswarehouse.com/performance/brand.php?makeid=5&modelid=29&year=2001&partid=4
Im a novice to this car upgrading business so any help/comments are apprecaited...
I can build a computer with my hands tied behind my back and eyes closed, but I look in a vehicle and go :banghead::screwy:
**Also anyone got a favorite website to buy this kinda stuff from? I just googled that and this site came up.
thorbergdt
03-29-2006, 05:41 PM
drdd
03-29-2006, 06:53 PM
do NOT use Bosch plugs. They do NOT run well in our trucks.
Search this forum for 'Bosch' and you will see nothing but problems. Go with ACDelcos. It's worth the extra bucks. You don't want to have to do the job twice when those cheap Bosch's crap out in a year.
thorbergdt
03-29-2006, 07:17 PM
where was the link to doing the install easily for these new plugs? i can't seem to find it in this forum!?! :banghead::banghead::banghead:
2000blazerls
03-29-2006, 07:23 PM
http://www.automotiveforums.com/vbulletin/showthread.php?t=503231
That is the how to on the #3 plug. The rest are easy. That one is a bitch to get out.
thorbergdt
03-29-2006, 07:48 PM
Anyone know of a spark plug layout and or diagram for locating all these plugs? sorry im kind of a newbie at this. I got that #3 thanks for the link.
2000blazerls
03-29-2006, 10:04 PM
No need for a lay out, just follow the wires from the cap. Only the third one is kinda hard to find and that link I provided shows you the easiest way to do it. Just use the right tools and be careful, you do not snap one off in the block trying to be in a hurry or getting frustrated. Also remeber the wiring, I did one at a time to make sure I did not mess up the firing order. Or you can label the wires as you replace them so you know which plug it goes to. That would be easy too.
thorbergdt
03-30-2006, 02:53 AM
yep i got it thanks a ton guys! A complete car novice as myself even managed to get that tricky #3 plug! granted it took me like 4 hours to do it all i still did it myself!
dmbrisket 51
03-30-2006, 04:39 AM
i quit reading when i seen bosch, i have a 98, and my cost (fulltime machanic cost through shop) for plugs wires cap and roter was 157, tuneups on our trucks are not cheep, sorry, the list cost on just the wires was 140 fricken bucks, if you want to do it cheep, you can, but, you will pay for it later, do it right, do it once, you (as every one else i talk with at work) are short on coin, so why pay to do it your way then pay to do it right in a month or less? the new style cap is what is hurting, they are new, and so they know that they can charge you a lot for any part of the ignition system, plat plugs, some wires from advanced auto or napa if you dont want delco, and a delco cap and roter for your tuneup (dont forget the air filter, fuel filter, pcv valve and check your end rails for wetness, almost 80k is almost 20k over due for a lower intake manifold set, if it hasn't been done yet)
2000blazerls
03-30-2006, 11:53 AM
Do you really need to change the lower intake set? I am sitting damn close to 80 thousand miles myself.
thorbergdt
03-30-2006, 04:11 PM
Thanks for the input on what else needs to be fixed/looked into.....
I went out and got a new battery to go along with my new plugs; I can notice the difference on startup for sure. How easy are the Fuel Filter/PCV Valve to replace yourself? I could have found a new hobby with this neglected vehicle:)
drdd
03-30-2006, 10:40 PM
PCV valve - easy - no tools - 1 minute tops !!
fuel filter - it's worth it to go out and buy "line wrenches". With those, it's a breeze ... you don't want to strip 'em. On a 2001, it's about that time ... search the forum and you'll find how and other tips ...
BlazerLT
03-31-2006, 12:33 AM
I would not worry about the wires too much.
5 year old wires will not need replacing.
Replace your plugs with AC Delco plats and change your cap and rotor.
Cap and rotor are more important than the wires.
