Front Speakers?
myk3
03-29-2006, 12:00 AM
how do i get to them on a 97 mirage? do i need to remove door panels? if so, how should i go about that? 2 screws then pop it off? thanks in advanced! :D
DFBonnett
03-29-2006, 08:05 AM
Removing the door panels on any car is typically not intuitive and difficult to decribe in words. Do yourself a huge favor and pick up a $20 Haynes or Chilton manual.
myk3
03-29-2006, 01:34 PM
ack!:banghead:
CAUTION
04-10-2006, 01:12 PM
alright i did this its not too difficult, granted i have manual locks and windows. remove the 3 screws in the door handle, the part of the door you grab to close, and one near the hinges. once these are gone pop out the door handle housing and the part of the door you use to close the door. once these 2 parts are removed reach down near the bottom of the door and there should be a small slot, grab and pull. you will now start to pop the door pannel off, i used a large flat head screwdriver to help as well. once you get the first panel off the next one will only take around 5 minutes. hope this helps
