Transmission Fluid
cwon
03-28-2006, 09:08 AM
Is it necessary to change transmission fluid often? I use my mini van to tow a 16-ft boat once in awhile and I noticed that the color of the transmission fluid is pretty dark color.
jrouter76
03-30-2006, 10:11 AM
Is it necessary to change transmission fluid often? I use my mini van to tow a 16-ft boat once in awhile and I noticed that the color of the transmission fluid is pretty dark color.If you are towing on a regular basis yes ,I know that for an average driver you should change your fluid every 50,000 miles but in your case you maybe 25-30000 miles...if it is dark it could be burnt ,smell it if it has a strong burnt smell to it then it is burnt and need to be changed ASAP
cwon
03-31-2006, 07:44 AM
Thanks Jrouter76 .... it's been 60,000 mls .. so I better get it done quick ..
cwon
04-17-2006, 09:41 AM
I just talked to the mechanic and he said if I have not changed the transmission fluid since the car is new (2000) and 60,000 mls, it's better to leave it alone ..
Then I went to another garage and this guy said I should change the fluid .
So who should I believe?
Igovert500
05-14-2006, 06:42 PM
Just change it. You said you already have 60k on teh car, so it's time. I personally do mine every 40k or so.
Also in hte future, if you have car questions, please post them in a different section. This intro section doesn't get alot of traffic, so fewer people will see or answer your questions.
Thanks and welcome to AF.
