1988 K1500 4X4 Front Axle Won't Engage
wolfden6
03-26-2006, 09:58 PM
I have a 1988 K1500 4X4 and the front axle will not engage when shifted into 4 wheel drive. I checked the acuator and it is working but the front axle will not engage.
Can anyone help me with this problem??
67malibu
03-27-2006, 07:19 AM
Are you sure the actuator is extended to full length?
wolfden6
03-27-2006, 09:02 AM
I am sure that the actuator is working fine.
I removed the actuator and use a short length of round dowel and pushed on what ever the actuator pushes on and rotated the wheels and the axle will not engage.I pushed as hard as I could and it still would not engage.
Any ideas on how to free up what ever is stuck???????????
wolfden6
03-28-2006, 05:36 PM
What exactly does the actuator actuate????
Could this thing bind up or get stuck in some way???(The part the actuator engages)
I tried to push on whatever the actuator pushes on and the axle would not lock
Any ideas??????????????????????????
horse482
03-29-2006, 01:12 PM
The accuator pushes on a shift fork. The shift fork is probably wore out.
wolfden6
03-29-2006, 03:21 PM
So how involved is replacing the shift fork in the front axle???
horse482
03-29-2006, 06:06 PM
Pull the housing that the accuator screws in to the shift fork is in there. I think that there are 4 bolts holding it on. Also look at the surface on the gear where the fork rides and make sure that it looks ok.
wolfden6
04-02-2006, 12:17 PM
Does anyone have or can anyone tell me where to get a illustration or diagram of the front axle so I know what I am looking for in the shift fork and the gear????
wolfden6
04-09-2006, 01:10 AM
when removing the axle tube to get to the shift fork, does the axle just slide out when removing the tube??
wolfden6
11-17-2006, 09:16 AM
Ttt
idmetro
11-17-2006, 10:35 AM
Here's a link to a diagram at LMC truck for the front differential actuator. Hope this helps. http://www.lmctruck.com/icatalog/cd/t112.html
rdptrans
11-17-2006, 03:09 PM
sounds like the tip of the axle is broken of, this will cause the axle to fall a little and not let the engagement sleeve slide onto axle, cause::: axle tip support bearing had failed.
wolfden6
11-17-2006, 09:36 PM
would that axle tip support bearing be the same thing as a output shaft bearing as shown in a axle schematic. Please go this link and see if that is the bearing that you are talking about (#5)
http://www.trademotion.com/partlocator/index.cfm?action=getLocator&siteid=213815&chapter=DP1008&appSectionid=20&groupid=10016&subgroupid=20059&componentid=60570&make=6&model=K1500%20pickup&year=1988&graphicID=T008130&callout=13&catalogid=1
rdptrans
11-20-2006, 12:04 PM
no. just in front of #16 you can get just the bearing from gm dealer. the bearing you are looking at supports the back of the axle.
wolfden6
11-21-2006, 12:36 AM
Thanks for the info, but which number would the bearing that you are talking about be??
Does that involve a complete teardown of the front differential??
rdptrans
11-22-2006, 02:51 PM
no remove extension housing and the gear and bearing will be right there. the bearing doas not have a call out#, go to the dealer and they should be able to find it for you. bearing is in front of #16 gear.
