Blown motor ?????
87camarocoupe
03-25-2006, 08:18 PM
:banghead: Put the camaro on the road today took it for a spin, raced a mustang overheated my motor bigtime now it making all sorts of noises and i got killed.:uhoh:
bag91
03-25-2006, 10:09 PM
Can you give some more details......noises and such
666_speed
03-25-2006, 11:08 PM
notice anything with the oil pressure now?
87camarocoupe
03-26-2006, 07:52 AM
its making some sort of knocking sound. I was wondering what kind of cars i can get a 3.8 out of and if it will bolt right in. I know i would need a new tranny if i wanted to drop in a 3.8
97cavalier
03-26-2006, 11:44 AM
ya you most likely bent a rod and it is knockin
666_speed
03-26-2006, 01:37 PM
3.8's came in mid 95 and went through 2002
87camarocoupe
03-26-2006, 05:06 PM
it sounds like its in the top end could it be a lifter or a valve or something. Does a 3.8 just bolt in the same motor mounts as a 2.8 and what other stuff would i need to change over
97cavalier
03-26-2006, 11:03 PM
you would need fuel upgrade like fuel pump and wireing harness, and you might need suspention upgrade also. i don't know if it is a bolt in or not.
87camarocoupe
03-27-2006, 07:17 AM
I am looking into a autopac writeoff so that way i have a donor car. so i should have the parts.
87camarocoupe
03-27-2006, 09:34 PM
can anyone tell me if it is easy to swap in a 3.8 in my 87 camaro (2.8):crying: . I an currently going to a mechanic school so i will have the tools to do it.
97cavalier
03-27-2006, 09:42 PM
if you are pulling the motor, mide as well go all the way and get a v8
666_speed
03-27-2006, 10:02 PM
i would think there would be just as much involved in changing from a 2.8 to 3.8 as to a v8 except maybe suspension parts....but i'm not certain
wrightz28
03-28-2006, 12:42 PM
:iagree:
For the mere simple fact that NO it's not just going to drop and bolt in. The 2.8L is a 60* motor, a 3.8 is 90* (essentialy a 305 5.0L minus 2 cylinders)
:iagree:
Engines Direct
03-30-2006, 04:36 PM
You mite try and put in a 3.4L out of a 93-95 camaro. Give me a call. Thanks JJ
stunnajosh369
04-19-2006, 03:46 PM
You'd probably get smoked by a 'stang on a good day with a 6 cylinder.. unless of course it was a 6 cylinder stang....
jveik
04-29-2006, 07:07 PM
lol screw the v-6 and the 305 for that matter. drop in a brand new 350 from gm goodwrench (they make them new still in Mexico lol). It only costs $1350 from jegs and i dunno if they have free shipping or not. it makes 260 horses stock form and 350 lb/ft of torque, so you might want to upgrade whatever tranny you have now to either th350, th400 or 700r4 trannies. maybe it already has one of them but i dunno lol... if you are going to be replacing motors anyways, then you might as well put that 350 in there maybe better cam and heads as well so you can get a 400+ horse engine that runs on 91 octane or even 87 with the right fuel curve and comression ratio...
before you go ditching your current motor though, i would try the old screwdriver trick to try to locate to source of the knock
