Performance air intake?
Cbioc32903
03-20-2006, 11:12 PM
I have a 1996 Grand Prix GTP with a 3.4L DOHC, and I can not for the life of me find a short ram or cold air intake for it anywhere!!!..Can someone please help me find one so i can order it?...Website or store, doesnt matter Thanks!!!!!
BNaylor
03-21-2006, 07:46 AM
Thats probably because there aren't any. Most guys with the 3.4L DOHC make their own:
3.4DOHC Cold Air Intake by Lowerd
To make a TRUE Cold Air Intake with the 3.4DOHC without moving the Battery if you have the K&N drop in filter:
Take out the box and expand the stock Snorkle hole to a 4" diameter hole.
Now remove the Rubber Grommet that the Snorkle was attached to the body of the car behind the headlights.
Go get a 4" diameter tube of expandable Dryer duct. That hole behind the headlight with the grommet removed will fit a 4" dryer duct nicely.
Or you can change that Flex tube on the stock intake for a nice smooth PVC pipe or go to the Exhaust shop and have them bend you a piece of Stainless Steel 3" Mandrel bent of course.
Madmunky
03-21-2006, 09:20 AM
yup...just like bnaylor3400 said...make your own. I'm going to be building mine the first week of April out of PVC pipe, you can buy a 10' section of the stuff for like $9 at Home Depot. I'm actually going to try and fit it over the battery box by relocating the windsheild washer fliud.
Jamie
Jamie
Cbioc32903
03-21-2006, 09:48 AM
Thanks guys you are always a help!:)
ern2112
03-21-2006, 11:59 AM
Is this as simple on the 98 gt? I noticed that even on the highway.....my actuall air intake temp is about 9 degrees higher than the outside...and in the city.....WOW.....WAY up.....over 100 if it is 75 outside or more.
Schuby87
03-21-2006, 04:00 PM
I have the same car, with same engine. Recently i put on a cone air filter but the car started stalling and acting funny. Then i got the error code p0410 secondary air injection malfunction. What does this code mean? Does it have anything to do with an air filter?
