99 Durango Liftgate Struts
razor3299
03-17-2006, 05:23 PM
Does anyone know where I can get the struts for the rear liftgate? I have one side that's sticking when I open it and gives a loud knock when it releases. I put some lithium grease on the rod and it eased the sticking a bit. Thanks.
Stevo2
03-21-2006, 05:15 AM
You should be able to get them through any of the major auto parts stores.
MeNBabyD
03-21-2006, 09:15 PM
I have a 98 durango and the left rear strut started making noise also.. also, when would open the hatch it "clunks" and shifts to the right a little. replaced the struts and still clunks... all hinges look ok and dont notice anything major.. any ideas?
jdq
03-22-2006, 12:15 AM
Maybe it is cockeyed
Stevo2
03-25-2006, 03:07 AM
Maybe the hinges are loose? Get an assistent to help hold the door and remove the gas spring/strut and see if you can move the door around any. sometimes when the door is under pressure from the struts, it's hard to see the problem.
