grinding sound on engine
4g63engine
03-14-2006, 07:38 PM
some grinding sound is caming out of my engine. i dont know what may be causing it is this a really bad problem. hpe not!!!!
ez1286
03-14-2006, 07:41 PM
do you have any type of logging device that can detect knock? Could be very bad, depends where it's coming from.
4g63engine
03-14-2006, 07:56 PM
i dont know ive never hear knoks earlier but when i was setting my maft.
ned032002
I'm not trying to knock on ya 4G63Engine but whats with the grammer? Will you also put your car in your sig? Sorry if I'm being a dick but it's just plagueing me and I needed to say something.
MexRocket
03-14-2006, 07:57 PM
could always drain your oil with lil magnet strips see if metal comes out, caming out as in the cams? Or you not knowing how to spell?
ez1286
03-14-2006, 07:58 PM
Are you datalogging with the maft? If not you should be at least a pocketlogger if not dsmlink. You may be running rich/lean and not know it.
4g63engine
03-14-2006, 08:10 PM
you are a dick!!! sorry for the grammar! i dint Graduate from school? my car was running without oil for a few miles. do you think this could be the problem?
ez1286
03-14-2006, 08:14 PM
Yeah that could cause some problems for sure. You most likely starved a bearing and then spun it.
ned032002
03-14-2006, 08:15 PM
Ok.:thefinger
No Problem but fixing it would be nice.
Running with no oil is bad.
And yeah it is a huge problem.
Ok.:thefinger
sganc4life_4
03-14-2006, 08:36 PM
It sounds like you need to stop driving this car before you cause anymore damage, first you say youve driven it while it was over heating and now without oil? Im sorry but you dont seem very intelligent...
4g63engine
03-14-2006, 09:10 PM
where do i start from?
NateS
03-14-2006, 09:34 PM
Well, I would figure out what the grinding noise is. You could try opening your hood while your car is ideling and try to identify where it is coming from. Oh and if you didn't put oil in it yet that would be a good idea.
4g63engine
03-14-2006, 09:38 PM
it was full of oil and sudenly it was empty? trust me i know how to change oil and check oil to cars. i ijust putted new oil and changed the anti freeze so it wont overheat i started the and it seems to work well. no noises 4 right now
Turbodog97
03-14-2006, 09:55 PM
Just because a noise went away temporarily doesn't mean that a vital problem could stilll exist. Running without any oil in the engine is extremely detrimental. Also, please be more specific with your threads next time, saying "some grinding sound is caming out of my engine. i dont know what may be causing it is this a really bad problem. hpe not!!!!" will not be sufficient to get a helpful response. Thank you
Blackcrow64
03-14-2006, 10:10 PM
You need to cut the shit and quite acting so arrogant. You do not have my respect for the way you are acting towards other members in this thread. :nono:
And learn how to type... :disappoin
SLoe
03-14-2006, 10:39 PM
How suddenly?
Get a long extension and put it against your tragus (the piece of cartilage in front of your ear canal :icon16: ) then put the other end on the engine in different locations (valve cover, oil pan, side of block, etc.) and determine if the noise is coming from the top or bottom of the engine. Let us know, and we will go from there.
How suddenly?
ned032002
03-14-2006, 11:05 PM
See Crows got my back.
SLoe
03-14-2006, 11:17 PM
oops damn dial up!!! Double post :sorry:
SLoe
Don't worry, I still love you :icon16::smooch:
OK, bad noob, use good grammar and spell check :rolleyes:
4g63engine
03-15-2006, 12:22 AM
sorry i was out for a moment. the noise does not exist any more. but i feel my car kind of slow it seems like it spools air but it doesnt gain speed.
Turbodog97
03-15-2006, 12:25 AM
Boost leak? Does the car jerk at all?
ez1286
03-15-2006, 12:37 AM
Do a compression check as well. Cheap and very easy, plus it gives you and idea where your engine is at.
4g63engine
03-15-2006, 12:42 AM
not really. its just that idont really feel power when i gas. also u gas for a while u will gain power but u have to shift up really quick and when i clutch my car stmles and it seem that i have a problem with the cluth too.
