fuel pump
talontsi26
03-13-2006, 10:55 PM
Will I need to get an aftermarket fuel pressure regulator if I install a walboro 255 fuel pump in my 93 rt tt?
Hotshot8792
03-14-2006, 09:55 AM
i would definitely recommend it so that you dont overrun your stock FPR
talontsi26
04-23-2006, 05:39 PM
Once I install an after market fuel pressure regulator, do I just set the fuel pressure back to stock? What is the stock fuel pressure? Any ideas on which brand of fpr to buy?
Hotshot8792
04-23-2006, 06:55 PM
Yes, you can set the adjustable fpr back to stock levels. Only raise it if your trying to get a little bit more out of your fuel injectors. When you set it after its installed, start your car, disconnect the vacuum hose that goes to the fpr, set it to 43 psi, then put the vacuum hose back on (the pressure on the gauge will drop).
http://www.importpoweronline.com/catalog/product_info.php?cPath=32_1_61&products_id=269
Chris has been a little bit behind on fulfilling his orders since he moved to work at 3SX, but thats where i bought mine, and I like it.
