rear brakes on 99 silverado
nick-g
03-13-2006, 07:42 PM
i replaced the pads and hit the rotors with sandpaper about 6-7 months ago. everything was good until about 2 weeks ago i hear a grinding noise when braking and most noticably stopping. i found today that the rear passenger pads- outside one is worn down to base and ate into my rotor and the inner is wearing fine but a little uneven. i dont know if its just the pads and rotor or the caliper or whatever else...
kenny-1907
03-14-2006, 10:20 AM
Did you lubracte the slide pins at all when you did the brake job, if not the caliper could be sticking which is most likely what has happened.
horse482
03-14-2006, 10:40 AM
Like Kenny said you needed to lubricate the caliper slides and pins. Make sure that you use a grease that is designed for brakes. Raybestos makes an excelent brake lube made of silicone, it works very well.
lilyorkie
03-24-2006, 09:43 PM
my calipers had locked up from fluid nasty/ contaminted, got new calipers and good now, bleed them, bet black crap comes out.
