98 V6 timing belt or chain
chazzce
03-09-2006, 01:23 PM
Does my 98 V6 SE have a timing belt or chain? I had my car towed to a shop and they said the belt slipped. I talked to the dealer who thought there was a chain and that it was almost impossible to slip.
chazzce
03-09-2006, 01:37 PM
Actually the shop that quoted $1150 the first time called me back and said he had already talked to the dealer and it was $800 to do one chain and would be silly not to do the other. When I talked with him originally he said timing belt (maybe simple mixup) but I am not going to let that cost me $1150 when he could not guarantee that was the problem.
Car ran fine 3 months ago. Needed alternator and didnt have time or money. Got alt. replaced but wouldnt start. Why would timing belt slip from when it did run to after I replaced alt?
mtmaurer8ooo
03-09-2006, 02:11 PM
It wouldn't unless whoever did the alt install is magical. It sounds like somesone made a boo-boo, and we really need some more information here. Also, you have a Timing Chain - the 4 banger has a belt - the sixer has a chain....two in fact...one for each side.
Jason43
03-09-2006, 03:20 PM
I've never heard of one instance of the V6 chain slipping/breaking in these cars. Sounds like this shop is clueless. What are the symptoms? Does it not start at all? Does it turn over?
chazzce
03-09-2006, 04:11 PM
Turns over fine. Just does not go vvroom. The shop said the compression was low. I dont know if that is one cyc. or all. A mech. friend said that the low comp. could be from setting for 3 months. Before I let it set for three months, if I let it set a couple days it was hard to start and I had to give it gas to fire up but once running worked fine. I did change fuel filter after it would not start but did not do any other diagnostics. (spark?, gas?)
